- Nov 12, 2017
- 12,678
- Plaster
- Pentair Intellichlor IC-40
Good call on checking that edge with a level, Kim! There was a guy here that got his pool all finished and filled, only to discover when they turned on the waterfall for the first time that it wasn't level, and water was dumping out on one side more than the other. Best to check for those kinds of things during construction, before the water is in the pool, when the fix would be a lot easier if something is askew. Especially when throwing a level on the tile is such a simple thing.
Here's some tricks for ya, as water is going to be a much harsher "critic" of level than any tool. First, sight down the edge of the level to make sure it is not twisted or warped. Place the level on the tile and observe the bubble. Then flip the level over, 180° vertically, and observe the bubble. It should be in the exact same place. Now rotate the level parallel to the ground, 180° horizontally, and observe the bubble. Then flip it vertically again. All four readings should be identical, which confirms the level is calibrated correctly and accurate. And, of course, the bubble should be dead center each time, confirming your tile is level. Check both walls. Then rotate the level 45°, with one end on one wall, the other end on the other wall, and check that the walls are level relative to each other. Do that test in several places along the walls.
If any of that is out of level, then water will not fall evenly across the entire edge. The "PB Fix" for walls out of level is to turn the pump RPMs up, causing the water in the spa to rise, which masks somewhat a shoddy tile job. At that point it's up to you to determine if that is acceptable or not. It wouldn't be to me, because that would require increased RPMs all the time to get the desired effect. Sometimes you might want your water falls to be subtle, and quieter, to set a mood. I would, anyway...
