New Build in Virginia
snakeeyes5
In The Industry
Aug 8, 2022
3
Northern Virginia
After working on the quote process and meeting with builders we've finally closed in on a design.
Gunite 18'x38' rectangle with 3.5-6' depth includes a tanning ledge with interior spa package.
Features
  • Autocover with stone covered bracket
  • Bubblers and lights in tanning ledge
  • Raised bond beam with 3x scuppers
  • 2x Skimmers
  • 2x Returns
  • 2x Drains
  • 4x Spa Jets
Equipment
  • Pentair ScreenLogic Bundle
  • Penatir EasyTouch 4SC-IC40
  • Pentair 320 Cartridge Filter
  • Pentair IntelliFlo3 HP VSF Variable Speed and Flow Pool Pump
  • 1.5 HP 240V Silencer Blower
  • 5x Pentair Globrite
  • Pentair 400k BTU Master Temp
Plaster, coping, and decking are TBD
More to come...
ensure the skimmers are independently plumbed back to the equipment pad. I think you should have at least 3 returns if not 4. One on each wall
Suggest you ask for an Intellicenter automation over the EasyTouch and Screenlogic which is over 10 yrs old. It is the newest technology
EDIT
Ensure the plumbing line to the bubbler and to the scuppers are independent lines. Also add a Jandy type 2-way valve on each line so there is control of flow. Avoid the use of plastic ball valves which can fail.
Make sure there is a light over the equipment pad. Much better than having to try to hold a flashlight on a dark night.
A hose bib by the equipment will be helpful also so you can clean the filter right there.
Features
  • 2x Skimmers
  • 2x Returns
  • 2x Drains
  • 4x Spa Jets
Equipment
More to come...
Congratulations on the design. I'm also in NoVA. Which PB did you use and how is the construction coming along?
