I started adding salt yesterday to switch to my SWG since it has been over 30 days.
My TA has been slowly dropping over this time as expected.
Per the IntelliChlor instructions the balance must be : PH 7.2-7.8, CH 200-400, TA 80-120, Salt 3200-3400.
TFP’s guidelines are almost the same:
FC 4-6 ppm
PH 7.2-7.8
TA 60-80
CH 350-450 for plaster
CYA 70-80
Salt 200-400 ppm ABOVE recommended optimum level
My numbers this morning:
TC 9
PH 7.7
TA 230
CH 250
Salt 2800 (adding more today)
CYA somewhere between 1-20 (CYA view tube was 99.9% full before I could not see black dot)
I read on TFP to overshoot TC and once it falls to the 4-6 range install and turn on SWG; that is why it’s high. TFP also says the TA in the correct range is important but for bicarb start up it says to let it go down slowly over time.
Should I wait to install the SWG until the TA naturally falls? Also should I add dry stabilizer to get CYA up or will that rise as TA falls?
