After a few life setbacks we ended up putting the project on hold.. but we're back on and are moving quickly! We ended up going with PB1, but extended the pool a few longer and made a few small tweaks. The area has been excavated, gunite and piping has been added, and most equipment installed. I'll add picks as soon as I can figure out how to add them!
Pool Specs: (move pool 4’ back & add 4’ length)
Perimeter 112 LFPool Area 626 SF
Depth 3’6” to 4’0” to 6’0”
Dimensions 38’0” L x 21’6” W
Spa Specs:
Perimeter 28 KFSpa Area 48 SF
Length/Width 6’ x 8’
Height Flush
Spillway Zero Edge Spillway
Contoured Multi-Level Benches
Hydro Therapy Jets (6)
Excavation:
Preferred Equipment – Bobcat Floor Compacted to Insure Stability
All Dirt Hauled Off
Steel/Plumbing/Gunite4 Bar Bond Beam #4 Rebar, Grade 60
Walls/Floors #3 Rebar, Grade 60 8” o.c.
Alternates in Floor
Stainless Steel Ties to Prevent Rusting
Hydraulic System all Schedule 40 PVC
Automatic Fill Line w/ Overflow to Maintain Water Level
Pressure Test Hydraulic System
Pneumatically Applied Gunite
Bond Beam 12” w x 18” depth (top portion of shell)
Walls/Floors – 6” to 8” thickness
5000 to 6000 psi (NSPI standard is 3500 psi)
Lifetime Warranty Against Pool Shell Leaking
2.5” trunk line for pool return
Pool Equipment Installation: All Pentair Pool Equip Includes 3yr Parts and Labor Warranty
Pentair Intelliflo Pump (Variable Speed Pump)Pentair 1 HP SuperFlo Pump (Water Feature Pump)
Pentair Clean and Clear 520 Cartridge Filter
Pentair Master Temp 400, BTU Heater NG (Gas Line Included)
Silencer Air Blower
Pentair Easy Touch 4 Function w/ Wireless Remote
Pentair Rainbow 320 Inline Chlorinator
Pentair Rebel Pool Cleaner
Pentair Intellibrite LED Color Pool Light
Pentair Intellibrite LED Color Spa Light
Electrical:
Wiring Installed to Meet all CodesAll Lighting Circuits are GFCI Protected
Tile/Coping/Water Feature/Decking:
Waterline Tile ($5 Per Sf Allowance)Travertine Coping ($10 Per SF Material Allowance)
Raised Beam Per Plan Center Wall 18” Raised | Left/Right Walls 12” Raised
4 Pedestal Columns; 24”x24” bricks with texture
Water Feature - 3 Travertine Scuppers Tanning Ledge - 6” Water Dept w/ Center Bubbler
Decking - 663 SF Spray Deck
Drainage - 175 Drain Line to Street 4” SDR 35 with tie-ins to downspouts/gutters
Pool Finish:
Interior - Pebble Sheen/Level 10yr Product Warranty
