- Jul 28, 2020
- 585
- Plaster
- Jandy Aquapure 1400
Wonderful site with tons of information. I hope to continue learning as well as being able to help others.
We have decided to build a concrete pool after having a 24 foot round above ground pool for the last 15 years. I have always used DE with an inline chlorinator and a Nature2 mineral system. Never have had a problem with algae except one opening with a bad cover(possibly from birds poking holes in it) that leaked into the pool. Water chemistry has always been a breeze with only needing to raise Ph and Alkalinity, usually only after heavy rain. Only other issue was high phosphates or phosphites, that the only solution would be to partial drain and refill. Didn't do the drain as the pool store said the issue was that the phosphates were a food source for potential algae which we didn't have to begin with. The plan is to continue with the same filter and sanitizing system with the new pool, just adding a heat pump for heating.
I know by reading through the various threads that I am in the minority NOT switching to saltwater. I just don't want to take the risk of not knowing if there are actually any drawbacks to saltwater. There's quite the divide to people that I have talked to. Some say saltwater is corrosive to the metal in the pump and heater. That the saltwater will corrode any furniture that is sat on while dripping wet and also the concrete patio will eventually crack. Now, I know this won't happen overnight, but what will these things look like 10-15 years down the road. Not to mention that the plaster may not react too kindly to the saltwater. Others say that none of these issues will happen. I have lost many of nights sleep contemplating this decision. I still have time to make the final decision as the build won't finish until next spring. Feel free to let your opinions be known on this issue.
The plan is to build a gunite pool with white plaster that is appox. 22ft X 44ft (with a 15ft wide X 8ft long tanning ledge that is 12in deep with 2 bubblers inside the perimeter). There will be two in pool loungers with a cooler table with the option for an umbrella. The depth is another undecided issue, but we are thinking 3.5ft to 6ft. More sleepless nights deciding on 6ft or 8ft depths. Please share your comments on this as well. We've been in both depths and one issue we had was hanging out or playing in the shallow end and then slipping down the slope of the deep end. We plan on using the pool for hanging out and playing games(volleyball/basketball) in it as well as cooling off. There will be DE, chlorinator/mineral system, with a heat pump and an LED light in the deep end as well as 2 LED lights in the bubblers. Also, 3 feet of concrete around the pool with about 600sq ft of concrete for furniture.
Still deciding which way to orient the pool to maximize the sun time. Any ideas as to which volleyball or basketball sets you would recommend would be very helpful. I plan to have anchors/sleeves buried into the concrete for the poles that can easily be removed and capped. Would love any opinions on the anchors/sleeves as well.
Thanks for reading and I look forward to the feedback.
Thanks
SecoSteve
Thanks
SecoSteve
