Just started the new pool (13,000gallons) and have two unusual issues that could possibly be related any advice on troubleshooting will be appreciated:
The cartridge filter is Pentair 160353 (200sf) with water coming out from the release valve as it supposed to and pressure gauge showing 10 during prime (max RPM). When RPM drops to 1400 then pressure drops to zero and water no longer comes out of the release valve. When I close it and open it, air comes out briefly (pressure was slowly building up when it was closed). So, it almost seems that cartridge is not providing enough resistance at low RPM to build the pressure and water just flowing through the filter? Is that a possible explanation and should i be comfortable with zero pressure and no water coming out of release valve during normal RPM? When taking out the cartridge, I can see that it is catching stuff, so, it's working but not sure if there is any place where water "escapes" too quickly towards outlet that prevents pressure build-up?
two caveats:
Here is the second issue that may or may not be related to this:
I have H2 FlowVis flow meter that is supposed to be on of the best. it shows 150GPM when priming at full speed (Superflo VS) and then around 45GPM at 1400RPM. both of these flows seem wrong - Supeflow cannot go to 150GPM (110 max) based on its flow chart and people usually get around 15GPM at 1400RPM. I am contacting the company to see what's going on but wanted to point this out here as well. So, basically, I have zero pressure in my filter at 45GPM and 10 PSI at 150GPM.
two caveats:
- I purchased the filter at a warehouse about 4 years ago. So, it was standing outside for 4 years before being plugged in. the cartridge looks fine..
- When looking closely, the cartridge itself is 150sf inside the 200sf filter casing - the size is the same and fits as it is supposed to. I am guessing the difference is number of folds on the cartridge and that should not make a difference in how much pressure builds, right?
