Hello TFP community,
I need some advice on a pool contract and to get a general idea of what you think of it. Dig is yet to start. It is a play/sport pool with 4” depth on either side going to 5.5” in the middle.
Thank you for your input.
POOL SIZE: 16’ x 32’ Depth: 4’ to 5.5' Area: 480 Square Foot Perimeter: 102’ Linear Foot Shape: Rectangle
GENERAL CONSTRUCTION SPECIFICATIONS (Includes Items 1-15)
1. Contractor will supply pool layout plans (Attachment A) and obtain swimming pool construction permits
2. Contractor will lay out the pool at excavation
3. Contractor will excavate the pool and remove soil on the day of excavation only
* Refer to rock clause within Structural Guarantee numbered 13
4. Contractor will concrete-gunite reinforced steel structure
5. Contractor will meet or exceed city or county codes for gunite / concrete schedule
6. Contractor will install 6" X 6" standard frost-proof tile
7. Contractor will install Limestone Leuders coping
8. Contractor will plaster with waterproof Quartz Fusion (Color TBD by Client)
9. Contractor will install 10’6”L x 21”D x 18”T water feature wall with qty.5 water spouts.
10. Contractor will supervise construction
11. Contractor will provide concrete pad for pool equipment
12. Deluxe 18" curved nylon brush, skimmer, telescopic pole, test kit.
13. Start up, brush down and pH control for 5-7 days
14. Complete instruction on pool equipment and maintenance procedures
EQUIPMENT SPECIFICATIONS (Includes Items 1-12)
1. Filter: Cartridge Size: 580 Quantity: 1
2. Pump Model: Jandy Vari-Spd HP: 2.5 Quantity: 1
3. Feature Pump: Jandy Vari-Spd HP: 2.5 Quantity: 1
3. Heater Model: JXI400NK Quantity: 1
4. Pool light (UL Listed): LED Jandy Pool lights Watercolor Quantity: 2
5. Automatic Surface Skimmers with Brass Cover Quantity: 2
6. Automatic Cleaner: Polaris 3900 Quantity: 1
7. Booster Pump - Model: Polaris HP: 3/4 Quantity: 1
8. Automatic Timer: Jandy Aqualink RS-PS8 Quantity: 1
9. Sanitizer: Nature2Fusion Chlorinator Combo Quantity: 1
10. Dual Main Floor Drains
SPA SPECIFICATIONS (Includes Items 1-5)
Spa size: 7’ x 8' Area: 56 Sq. Ft. Perimeter: 30 Linear Foot / Number of Jets: 8
1. Raised 18”.
2. Spa light (UL Listed): LED Watercolor Quantity: 1
3. Spa Blower - Model: PSB215 HP: 1.5 Quantity: 1
4. Spillway type – Custom
PLUMBING SPECIFICATIONS (Includes Items 1-6)
1. All lines to be schedule 40 - PVC
2. All suction lines to be plumbed separately
3. P-Trap and backwash line - TBD
4. Pool fill line and pool overflow line to be stubbed
5. Gas line permit and gas line to heater: Natural
6. Gas line reroute: TBD Sewer reroute: TBD Sprinkler reroute: TBD
ELECTRICAL SPECIFICATIONS (Includes Items 1-3)
1. Electrical bonding of pool and GFCI installation
2. Electrical service from existing meter base to pool equipment
3. Electrical reroute: TBD Electrical sub-service panel: TBD
- What do you think about the depth/size of pool?
- What about equipment specs? I was considering changing it to Pentair line but wasn’t sure. I did ask about SWCG, but was recommended against it.
- What do you think about the heater size? How would a hybrid or a heat pump version compare?
- Plaster wise, currently I decided on Finest Finish Radiant Fusion either in Regal Blue or Blue Jay. Any idea how this compares to other alternatives? I feel the PebbleTec lines are too “busy.”
- Coping I’m planning on changing to Travertine
1. Raised 18”.
