WOW! That page is now bookmarked
As far as CYA, what if you don't have a skimmer basket?
I dispise the chlorine tabs so I can really get behind not using them!!
And I promise not to spend another penny without checking with y'all!:bowdown:
Sounds like you found TFP just in time with your hubs being laid off. I hope it is for a short time or he finds another job fast.
Take all of that stuff back except the CYA.
HUGS!
Kim
How much of what you buy depends on how far from it you are. Since it's "New" water you aren't going to be doing a SLAM so you likely only need 2-4 Gallons of bleach to start off with. The place I get it from is about 5 miles away so I usually get a 4gal pack at a time unless I need to SLAM. The further away the store is the more you want to have on hand but you also don't want to store it where it's warm or for too long. Heat will degrade it so outside near the pool in the sun is worst. If you can find some place that's cool like a basement or ... whatever you can do to keep it from sitting in the heat and getting cooked.
The pH up, down will get used but likely be around for a while. After they are used up you can go with the cheaper baking soda (up), muratic acid (down) route.
