New AGP Build Southern Ontario
ashtonfitzgerald
273
Oshawa, ON, Canada
Hi TFPers! It's been a long, long winter here and as we roll into March (and what seems to be a never ending pandemic) I'm starting to look towards summer with great anticipation. I expect we'll be spending PLENTY of time at home again this summer.
We still have some lingering mounds of frozen snow around, and the ground is still a solid block of ice. So what better time to start planning for a pool upgrade! :) Our swim season generally doesn't begin until at least mid-May sometimes later, so we have some time to prep for a more permanent AGP installation.
For the last four years, we've been playing with a tiny Intex 12x30" metal frame. It's reaching the end of it's lifespan, and though the liner is still in reasonable shape (holds water), many of the poles are rusted to the point of threatening a flood of tiny proportions. We're considering upgrading to an 18' x 54" round AGP.
At this point it's all early planning and budgeting. Having done the install of our intex (complete with foam padding underlay), I'm considering taking on the this project as a DIY game. I've got four helpers that I'm sure would be eager to lend some hands as well.
I'm hoping for some feedback on pool wall options. One supplier that has a great reputation and is local to me has both aluminum or steel wall pool kits available. Does anyone with an aluminum walled pool have any feedback on theirs? I'd like to keep the option of a future SWCG open, so will be going with resin components.
I appreciate any feedback!
kellyfair
4,131
Tampa, FL
Intex Krystal Clear
Lots of folks will be chiming in, I’m sure! I don’t know much about permanent AGP as I have just purchased my first non-Intex pool, but I would go for whatever is going to hold up with your winters and has the least risk of rusting!
ashtonfitzgerald
273
Oshawa, ON, Canada
Thanks Kelly. Per your signature, what size is your old Intex filter and pump that you're using with the new pool?
kellyfair
4,131
Tampa, FL
Intex Krystal Clear
It’s this one, .75hp. It’s actually moving the water really well, but it’s oriented to Intex pool so the pump is on the right if you are standing behind it looking at the pool, and the filter is on the left. My new pool is the opposite, so I’ve got the plumbing crossing over from right side (pump) to left side (skimmer) and vice versa for filter to return. It is driving me nuts!
ashtonfitzgerald
273
Oshawa, ON, Canada
Thanks! I'll be sure to read through your build thread later on. It's good food for thought on my build. I don't have an outlet close enough for a new 1hp pump, so electrical work would be needed for the new pump. As a staging (aka cost management measure) I may try running the current pump for a few months before upgrading. Once swim season starts, I suspect it will be a different ball game.
On that note, I can get a 1HP Hayward Ultra Pro above ground pump (Hayward SP2290) for a good price ($269CAD). I believe this is an uprated pump, but can't find specs on it. Another possibility is a Hayward 1.5hp 2-Speed Turbo Flo II (Hayward SP57152) which is only $80 more. Again, I can't easily find specs on energy usage or flow rates for these pumps.
We have a solar setup that we use for approximately 6 hours each day. It's at the same physical level as the pool, so it's not like a roof mounted system that would need a stronger pump to overcome the initial head. I feel the 1.5HP 2-Speed would be overkill for 7600gallons. I like the energy savings option of a lower HP pump though. Our electic rates run about 20¢/KwH during the summer day hours. A single speed 3/4HP inground pump is $10 more than the 2-speed Hayward.
I feel myself developing paralysis by analysiso_O
kellyfair
4,131
Tampa, FL
Intex Krystal Clear
I know what you mean! But seeing the kind of circulation I’m getting now, I think a 1hp will serve my needs nicely, but I definitely want a 2 speed.
Novak77
20
Santa Cruz, CA
kellyfair
4,131
Tampa, FL
Intex Krystal Clear
Just checking in... did you manage to find a two speed 1hp pump yet? I see a Pentair Optiflow which offers this but I have no idea if this a good product or not:
I haven’t looked much this week, been too busy with work and trying to resolve a stupid fast drip at my return! I haven‘t heard of Pentair, so I don’t know either. I see they are sold out of Waterway... I think @magiteck has one of those.
ashtonfitzgerald
273
Oshawa, ON, Canada
I haven't been able to find any 1hp 2-Speed pumps for sale in Canada for a reasonable price point compared to the 1.5HP pump I've been looking at. Bringing a pump in from the US will end up costing a lot more than buying one locally, so I'm pretty sure the Pentair is out for me. From what I have read, Pentair pumps seem to be well built.
ashtonfitzgerald
273
Oshawa, ON, Canada
I'm ready to take the plunge and get my pool ordered. I want to do it sooner than later as last year, supply sold out super fast. Today is a warm, sunny spring day so I trekked out into the mud out back and measured out an 18' vs 21' round pool. We have a decently large yard, so space isn't an issue. At this time I'm liking the look of the 21' pool. It's effectively 3X the footprint of our current pool! I'm not so sure about digging out the spot for the install, but I figure many hands can make for lighter work;)
Novak77
20
Santa Cruz, CA
I have no idea if this is available in Canada so apologies in advance if you already saw this and can’t find them:
I think it’s available in Canada now I look, but the price may be reliably high as you already said!
the Pentair I’m looking at is evidently on back order so I’m considering this as a backup.
Reactions: ashtonfitzgerald
magiteck
373
Neenah, Wisconsin
Yeah I have a Waterway pump that I’ve been happy with. Honestly they seem to use the same Century motors that the others use — so it’s just the wet end that might be somewhat different.
I just upgraded over the winter from a 1.5hp SS Waterway Hi Flo pump to an identical 2 speed version. I would have gone with a 1hp 2 speed but I couldn’t find any available in horizontal discharge to go with my cartridge filter. I plan to run on low 99.9% of the time so figure it didn’t make a ton of difference.
Not sure what shipping looks like but that Waterway pump linked here looks like a great deal. I paid $372 shipped from Inyo for my new one. Hoping to recoup a chunk of that when I sell my old SS pump. Just too early in the year around here for “normal people” to be shopping :)
Reactions: Novak77
Novak77
20
Santa Cruz, CA
Good to know and thankyou for the review! I’m going to call on Monday and if they don’t give a good answer on the back order issue, I’ll see if I can find a waterway 😎
ashtonfitzgerald
273
Oshawa, ON, Canada
It’s been a quiet month on the pool front here. Some beautiful days in March got things thawed out, and unfortunately work was very busy. The pool was delivered just over a week ago and yesterday’s sunshine provided a great opportunity to clear out the old one. Several hours of siphoning and a pump running, we drained the little beast and took it down.
Anyone in the GTA looking for some intex pool parts? The T’s and uprights are still in great shape. About half of the horizontal poles are severely rusted.
Uploading photos from my phone is janky at the moment and I don’t have the patience to fiddle with it...
