The hose is supposed to float.Finally started the process connected up and have some suction tried to sink the whole cleaner hose and it’s still floating pump is running
I’m attaching pictures of the cleaner and pictures of the pump
That hose looks to be compromised, some sections have what looks to be a permanent curve in them. When they are pulled apart, each section should be straight. If they aren't, likely the whole hose was coiled when removed from the pool for storage, even temporarily, like when the pool is in use. Even a short time in the Sun will cause the hose to do that and it will not straighten out, no matter what you do.
