My Hayward 1.5HP SuperPump is on its last legs. It is about 8 or 9 years old at this point, and I already had the bearings replaced on it 2 years ago. It's currently making such a loud noise that you can't have a conversation if you're standing next to it. That said, I'm trying to figure out if attempting to replace the filter on my own will be more trouble than its worth.
Regardless, I want to make the best decision when it comes to purchasing a new pump. It's clear that a variable speed pump is definitely the way to go, and to provide some information, the pool is 27,000 gallons with two returns and a line for a water slide/waterfall which were never actually installed. There is a center drain and a skimmer. A few questions:
1.) Is replacing the pump a manageable job for one person? I tend to be good with repairs, but don't want to bite off more than I can chew.
2.) Should a VS pump require more/less/the same horsepower?
3.) My filter and control panel (Goldline Aqua Plus) are both Hayward. Is there a benefit in purchasing a Hayward Pump? And along those lines, is there a specific pump that I should consider?
4.) I have never replaced the sand in the filter. Is that an issue?
Thanks so much!
Thanks so much!
