I just installed a SWG last week and ended up putting too much salt in. Had to do a partial drain and refill. My reading as of today are:
FC 5.5
TA 90
PH 7.6
CH 190
CYA 60
Salt 3800 (from K-1766)
Salt 3430 (from Clorox Strips)
Temp 84F
From reading the "Water Balance for SWGs" article it seems to suggest that I lower my TA to 50 or 60 and raise my CYA to 80. Also, I am confused about the CSI and LSI calculations. The Circupool SWG manual made a big point of keeping the LSI between -0.2 and 0.2. With the reading now it is LSI is -0.11. If I pull the TA down to 60 the LSI will be -0.35 which Circupool says is bad. If I let the PH rise to 7.8 and keep TA at 60, LSI moves to -0.16 and I'm good again.
As you can see, I am confused. Before I start adjusting chemistry, I am looking for advice.
Thanks
FC 5.5
TA 90
PH 7.6
CH 190
CYA 60
Temp 84F
Thanks
