- Jul 5, 2010
- 85
- Plaster
- Hayward Aqua Rite (T-15)
So, long story short, due to a dead SWG, I ended up with too much salt (>5,500 PPM) and a green pool.
So, here shortly one the sun starts to set (I’m just outside Houston and its dang hot out now) I’m going to run tests, get my FC, CTA, etc. readings.
In the meantime, to help bring the salt ppm down, plus my pool has been reading a fairly consistent 8.2 pH reading, I was thinking I need to and should dilute my pool.
Was thinking of turning off the pool filter, dropping a garden hose in the deep end, turn it on, and let the overflow valve vent the excess out. Run the hose a few hours, which should help exchange some of the water.
Hoping this would dilute the water to a manageable level, and then the SWG could start running again and producing chlorine.
Does this approach make sense, or is there another way I should go about this?
