Not so quick questions:
Our pool was finished Apr 2020 and I remember it would not hold chlorine or CYA and inwas
Now our pool store score is 50, cya over 150, starting to get green buildup on walls, and need to drain. Report attached
I was planning to replace half the water and use the pump backwash setting with the main drains and close off the skimmers. We are reading never use the pool pumps and also never above 80 degrees which it is.
we are still learning and any guidance is appreciated, thanks
