Need someone with ScreenLogic in the DFW area to test something for me...
Jimrahbe
35,755
Bedford, TX
I normally get the following page...
The weather updates from the local airport.. You set it up on the following page..
Mine is stuck and I can not get it to update anymore.. When I tell it to find the airport.. It just spins the small wheel of death and then says not available.
Not sure if it is just me, or if Pentair did something on their end..
Please let me know any results..
James,
That is what I had in there already. The pic is an old one. I erased it and entered it again exactly like your example. No go. It used to find the airport on its own. That is what I was hoping some one with Screenlogic could test for me.
Thanks, it was good to know I had the right code in there..
Anyone should be able to test it. It should not be related to where you are. You can try a different airport to see if that makes a difference.
Or, maybe try putting in a different zip code to see if that makes a difference.
