I have had my setup for 3 yrs now, Pentair ic40, Pentair 250 heater, pump etc…
Never had a problem till I screwed it all up. Long story short ended up dumping I’m 5 or 6 bags more then I should have and water turned green. IC40 shows green salt, green flow, but status light is blinking green indicating a bad cell. I drained the pool and added fresh water, set the salt at 3600 according to strips and it appears the cell may have taken a dump. I acid washed it with an end cap on it, 1 part muriatic to 4-5 parts water, no sizzling , plates looked clean. Looking for anything I should be doing. I shut off the breakers and did a diagnostic afterwards and cell life is shown to be 60%, fwiw. The pic I provided is the actual unit. Thank you
Kevin
Kevin
