There’s no finite amount of time for
SLAM Process completion although doing certain things help it along as mentioned above-
* testing fc & replenishing to slam level frequently (every couple hours is ideal but at least 3-4 times a day) every hour below slam level for your cya algae grows.
* brushing &/ vacuuming at least daily (this breaks up the biofilms that algae uses to protect itself from chlorine allowing you to murder it)
* backwashing when filter pressure rises 25% over clean pressure (this can be a chore w/ a d.e. Filter since it’s sooo good at its job & clogs quickly)
* scrubbing ALL the nooks & crannies such as- light niches, skimmer throats & weirs (even the foam), water features, steps, ladders & their cups, drain covers etc.
*Run all water features for at least an hour every day so they get slam level fc in them
