I need a new pump.
My pool is 18k gallons. Two skimmers, 1 main drain. 3 1.5 suction lines running to the pad. Two 1.5 return lines running back to the pool. I plan on adding a water feature in the future. Pentair clean and clear 200 cartridge filter.
What I'm looking at doing is replacing my PVC valves on each suction line with Neverlube valves. I'll go 1.5in into the valve, and then 2in out right into 90/T so the manifold between the suction lines and the new pump is 2in. Then install a new Intelliflo VS pump. On the pump output I'll replumb 2" to the filter inlet. I'll leave everything on the filter output 1.5in for now, then upsize it to 3in when I add a 3rd 1.5 return line and three way valve to my water feature.
Does this sound like a reasonable plan and a good fit for the intelliflo? I looked at the sureflo as well, but I'm interested in the low cost Intelliconnect automation that works with the intelliflo.
