It’s a process. Go slooooooooooooow to reduce the cloud. But with each pass you get more out, and progress is progress.And when I do vacuum, I can see the blue bottom much clearer but the more I do, the cloudier it gets
The more you do it, the faster it will clear.And when I do vacuum, I can see the blue bottom much clearer but the more I do, the cloudier it gets. It seems like a fine dust has settled on the bottom. For vacuuming I use a catfish vacuum.
Lol I do! I’ve had one for years and found out early on to go as slow as possible.It’s a process. Go slooooooooooooow to reduce the cloud. But with each pass you get more out, and progress is progress.
I do not.Do you have access to an "old skool" pool vacuum that is hooked up to your skimmer with a hose? The Catfish filter is not great at small particles. I have the slightly bigger version for spot cleaning. Vacuuming to filter will be better to get rid of the "dust".
I do not
It’s charging now. I got maybe a 1/3 done. After this gets cleared up, I’m going to need recommendations on a vacuum to buy. We’ve had the catfish for years, but i replaced it with a new one at the beginning of Summer. I had no idea what would work with our pump so I just bought another one.The more you do it, the faster it will clear.
In person and away from the nanny filter, Adult words are used to describe it.Lol. Stupid clear.
Thank you so much! I will def check it out the next time I’m in town. I’ve seen the head at menards but I always thought it wouldn’t help. Now can I use my sand filter with this?You need a pool vacuum hose:
Inground Commercial Grade Flexible Hose 1-1/2 in Diameter, 40 ft
Doheny's Inground Commercial Grade Flexible Hose 1-1/2 in Diameter, 40 ft. Hurry and purchase today at Doheny's Pool Supplies Fastwww.doheny.com
And a Vacuum Head
Flex Vacuum Head-Doheny's Pool Supplies Fast
Flex Vacuum Head-Doheny's Pool Supplies Fast - Purchase today from Doheny's Pool Supplies Fast.www.doheny.com
You should be able to get these at your local pool store. Measure the distance from your skimmer to the furthest part of the pool, add 5-10 feet and that is the length of hose you need.
You pull the skimmer and close the valve to the pool main drain (100% skimmer). Attach the head to a pool pole and the vacuum hose to the vacuum head. Put the pole/head in the pool and now starting from the head end, push the hose under water to fill it up. While under water, put your hand on the open hose end and pull it out of the pool, making sure as little air goes into the hose as possible. Move it down into the open skimmer and push the end of the hose into the skimmer suction. You now have a "Standard - Old Skool" pool vacuum.
I used to clean apartment complex pools in the 1980's this way, as a lifeguard. It is work, but it sucks everything to filter.
It’s more of a greenish yellow. I’ll take a pic shortly of pool now after I’ve vacuumed twice today. This is my last go around pic with the vacuum bag. Not a ton of color as from when I first posted.That pretty green looks like copper mixed with chlorine to me. Silver turns black. Iron turns brown. Magnesium turns purple. A combination of all will just turn it dark brown red. Copper can come from a well, copper piping, and algaecide. This color is different than algae green. It’s obvious from your filter you do have algae but that overall color is metal imho. Personally, I think it looks pretty but I might be wired different. Getting it out? That’s the hard part.
Just posted one, I had to go back out lolHow about a picture of the pool?
I ordered the vac and hose too.Just posted one, I had to go back out lol
When we are done with you, You will post ones here :It looks better in person. Today is the first day in quite awhile that it doesn’t look awful
