Moved from here.
Hi, I have this same problem. Hope you can help. Easytouch 8, brand new unit. Installed valve actuators and they move correctly from pool to spa configuration when I toggle the switch on the actuators themselves. They are plugged into the intake and return connectors on the ET8 board. But when I switch between pool and spa mode on the ET8, the valves do nothing. Regardless of which ON setting I toggle the switch to, they don't respond at all when I switch modes on the control panel. Seems like I'm missing something simple. Thanks in advance
