- Apr 3, 2025
- 23
- Plaster
- Pentair Intellichlor IC-40
Hello everyone, I have recently had my pool servicer install a SWG and I am curious how to read/interpret what's going on with the IC40.
For reference, here is how my system is plumbed:
Pool Water Return -> Pump -> Filter -> Heater -> Check Valve -> IC40 SWG -> Pool Water Send
Note: At Pool Water Return I have 3-way valve that will turn this into Spa Water Return; the same situation at Pool Water Send, I have a 3-way valve that will this into Spa Water Send.
Questions:
1. My servicer installed the SWG downstream of the heater, which I believe is the correction orientation. This prevents highly concentrated salt water generator outputs from entering directly into the heating elements in the heater and prolongs the life of the heater. Is this correct?
2. My servicer installed a 1-way spring door check valve that allows flow from the heater through the IC40 SWG, but stops reverse flow. This is also to keep highly concentrated salt water generator outputs from entering the heater via backflow. Is this correct?
I have my pump set to 2 different schedules. 0800-1100 @2800RPM and 1100-1600 @1500RPM. Other than those schedules, the pump is off. When the pump is running at 2800RPM the IC40 seems to be running okay with all lights/functions working normally and the check valve is open a good amount, letting me know visually that water is flowing through the system appropriately.
3. At 1500RPM, the check valve is not fully open but water seems to be flowing since I see bubbles at the top of the check valve window. The IC40 has a red light for flow, meaning that the IC40 isn't receiving enough water to flow appropriately. Is this situation okay for 1100-1600 @1500RPM? Any adjustments needed?
4. When the pump is fully off, the IC40 has flashing red and green lights in the Salt Level readout section. But the pool has been verified to have appropriate salt content. Is this okay? Or should the pump be running to provide flow at all times?
5. The IC40 seems to be performing and doing its job when the pump is running the 0800-1100 @2800RPM schedule. Will 3 hours per day of appropriate function be enough to keep the pool in check?
I am new to the homeowner and pool life. Any tips or help is appreciated. I've lurked this forum a little bit and happy to be a member now!
Questions:
