Need help with figuring out pool automation!!
gabemtz83
3
Tampa
I'm in the process of getting a pool built and am working with a pool company who seems challenged with automation. I work in the Audio Video industry so automation is pretty much second nature to me with that stuff but need a little assistance with figuring it out what i need.
Current Pool setup:
(2) Intellibrite Pool lights
(1) Glowbrite Spa Light
(2) Magic Bowls with FireFx LEDs
Pentair Intelliflo VSF Pump (shared with spa via valve)
Heater
(1) 24" Waterfall
(2) Deck Jets
The water features can be all on at the same time if need be, but prefer to separate them. I really want to use a Jandy panel so i can integrate with my Savant Home automation but they say you cant control the flow of the Pentair pump only the speed. Just looking for some advice! Thanks!
Jimrahbe
14,005
Bedford, TX
Gabe,
If you want to use the Jandy panel, why not just use a Jandy pump?
We always recommend that the Automation, any VS pump, and any SWCG, all have the same manufacturer.. Once in a while things are interchangeable, but for the most part mixing and matching does not work well.. When things don't work, it is always the other guy's fault... :)
I can 't think of a single reason that anyone "needs" a VF pump... Changing speeds works 99.9% of the time.
You should check out the new Pentair IntelliCenter.. It takes the place of the older EasyTouch or IntelliTouch.. You might want to check out what it will interface with.
Jimrahbe
14,005
Bedford, TX
Allen,
Jandy can control some IntelliFlo VS pumps or the VS option of a VSF pump, but it can't control the VF option...
For some reason the OP needs the VF option..
Jimrahbe
14,005
Bedford, TX
Allen,
I'm just guessing here, but this is the way it appears to me... Several years ago the Big Three (Hayward, Jandy and Pentair) decided to share their RS-485 code, so that they could control each others equipment.. Not sure why that did not continue, but as time went on, the firmware running all these systems has changed, but the Big Three no longer keep this interchangeabilty in mind when they update their firmware..
A good example is the OP's problem... back in the day Jandy's F/W was made to talk with the IntelliFlo VS.. then Pentair developed a new pump that was both a VS and VF pump, the VSF. Jandy's F/W has never been updated to drive the VF portion of the VSF pump...
This is the main reason that we always recommend the same brand for products that need to "talk" to each other. It just makes things easier for installation and warranty issue.
gabemtz83
3
Tampa
Is there any reason to even have to control the Flow? I mean if its not that big of deal i can just leave that out or am I doing myself wrong by not having that. Thanks!
Jimrahbe
14,005
Bedford, TX
Gabe,
In the old days, Pentair sold two pumps.. VS and VF.. At that time we always recommended the VS and never recommended the VF..
Now Pentair makes one pump that can do both.. VS and VF... For some reason people have fallen in love with the VF option..
If I had the VSF pump, the VF option would never get used. :)
For the normal pool owner, there is never a "need" to have a VF pump..
Jimrahbe
14,005
Bedford, TX
Allen,
The 011028 is the new replacement for the old 011018 VS pump.... It has a different control head that can be rotated..
