Hello TFP community -
I just purchased a Raypak Crosswind 50-I heat pump. Reading through the manual and online forums, I'm seeing conflicting information (and mostly a lack of information) on how to properly operate this thing...most notably:
The display allows me to turn the heater on and off (then set temp, etc). However, it states very clearly that the pump MUST be running at all times when the heater is on, otherwise I will void the warranty (see image below). There is no timer on this heat pump unit, so does that mean I need to keep my pump running 24/7 in order to maintain my temp?
I have read (and am aware) there are built-in protections to turn the unit off if it senses a lack of flow...so in theory when my timer turns off the pump the heat pump will shut down, but that seems more like an equipment protection sequence, rather than how I should "plan" to operate my system.
Related, I am planning to install automation in the future (thinking the Hayward Omnihub), which will operate the heat pump and solve this problem, but I'm not there yet.
Thanks in advance for any help/advice!
