- Mar 17, 2024
- 72
- Plaster
- Astral Viron V25
Hi, we moved in to a new house that came with 30 y.o pool. We are reaching out to anyone here for advice. what to do after retiling, regrouting with epoxy grout and refilling the pool. We don't know anything about the pump and salt water chlorine converter device but they look newish, we have never use it. I assumed it is a salt water pool. It's a concrete swimming pool with marblesheen/ marblelcrete lining behind old tiles finish which we retiled. It is a 12,000 gallon pool.
Do we run the pump first, backwash, do we need to check the SWG, and what to check? And when do we put chemical and the order of the rest of chemicals to balance the pool.
These are the test result: done by the pool shop this morning:
FC 0.26, pH 7.3, TA 56, CH (total hardness?) 99,, CYA 0, Salt 147 ppm. Temperature 71.6F. Phospates 0, Copper 0.1
We also try to put the datas on TFP PoolMath. Appreciate all the advice. Thankyou.
