We have an 18 foot x 45 foot oval above ground pool that is 4.5 ft deep. (approximately 21,500 gal) Vinyl liner, one in-wall skimmer with an 18 in (I think) sand filter and a 1.5 HP pump. This will be the 7th summer we've had the pool. The filter is original, but we've replaced the pump twice already. I think it originally came with a 1 or 3/4 HP pump. When we closed the pool last year we had some small leaks around some of the valves/attachments. Upon opening this year the pump won't start up and there must be a crack in the bottom of the filter as it is leaking now as well. We want to replace the whole filter/pump set up. The pool's metal frame is designed with 2 available cut-out spots on opposite ends of the pool for the skimmer and return jet, but it only came with one filter/pump set up. We have a Hayward automatic pool cleaner, but it has never worked well on the end of the pool away from the filter/pump. I have wondered in past years if we should add another unit on the other end. Now we have no working pump or filter, so my question is this:
Do we get one pump/filter that is big enough to handle the entire pool or do we get 2 smaller pump/filters so that each end stays cleaner (by moving the automatic cleaner) and if one fails we still have the other one as back up?
Thanks for your opinions!
