Need help raising CSI
Steve21
Active member
Jul 25, 2020
26
Inland Empire, Southern California
Pentair Intellichlor IC-40
numbers are as follows:
PH 7.2
TA 90
CH 475
CYA 80
Water temp 64*
Salt 3900
BOR 50
According to the pool math app, these numbers are within target, close to ideal. CSI shows -.64
how can I raise CSI and get close to zero?
With cooler water, your pH is on the low end. Let the pH rise up to about 7.6-7.8 and you should be fine.
PH can be raised in three ways: borax, soda ash, and aeration. Borax is usually the best choice.
The Ph is purposely low and am aerating, to lower the TA. It was at 110 a few days ago
Don't be so eager to lower the TA.
If the pH gets to 7.9 or 8.0, lower the pH to 7.8, and not lower.
I would just allow the pH to rise back up naturally from aeration.
I would not intentionally try to lower the TA any more.
As you add acid to lower the pH to 7.8, the TA will reach a natural equilibrium.
Reactions: Leebo
Will that help with the CSI aswell?
