We just purchased a new house, and I am now the owner of a pool that is way out of my depth, and I need some help figuring it all out. I don’t know a ton of details about the pool. It’s less than 3 years old, ~15,000 gal, and of an unknown finish. It’s a saltwater pool with a Pentair Intellichlor Generator and a Pentair Easytouch Control System. There are also dual VSP.
The water is beginning to look on the murky side so I’m having some concerns about the water chemistry. But I’ve never owned a saltwater pool, so I’m honestly not too sure what I should be looking for as far as balancing goes, what chemicals I should be adding to keep everything clear, if my system is working correctly, etc. Should I be adding chlorine? There are tabs on the side of the house from the previous owner. Do I add salt?
I have a TF100 but I need to refresh its contents, so I went ahead and used these test strips for now (not ideal, I know). Results are below. The measurements from top to bottom are total hardness, total chlorine, free chlorine, pH, total alkalinity, and stabilizer. Looks like I'm high on the TH, pH, and TA.
And here is the reading from the Intellichlor App. I have no idea what this is measuring or if its good or bad:
And here are some miscellaneous pictures of the equipment. I will take all comments and advice you can provide.
And here's the pool itself.
