So I am being told I need to run 2 IC60. My pool is close to 75,000 gallons. Having a Easytouch 8 being installed next week for good price but contractor wants way to much to do the salt conversion. Anyone have any info on running dual units.
Does the Easytouch come with the Intellichlor power supply built in and an IC60 cell?
You can add a second Intellichlor power supply box next to the Easytouch box and then have two cells.
In my opinion, you probably don't need two cells.
What is the builder's plan for the installation?
We have seen folks here who have multiple Pentair Intellichlor cells in a master/slave setup. One is designated the Master and the others are the Slaves. All % adjustments are done to the Master cell.
I have never been able to find any description of that on the net.
So does the slave unit change when the master does or it that pre set and then use just master to change to get proper salt level
Yes we are on same page. I misspokeKurt,
With the commercial units, there is a master and slaves.. I don't believe this is true for the residential units..
The EasyTouch can only control one cell...
Just to make sure we are on the same page.. The only thing that you can change on the cell is the Percent of Output.. 0 to 100%. A salt cell does not make salt, it uses the salt in the water to make chlorine.. By adjusting the cell's output you are telling the cell how much chlorine to make.
Thought the same thing about the sun. But doing some research a UV light is way different than the sun. The type of UV light that comes from the sun that is the same as a UV bulb is almost nothing by the time it reaches the surface of the earth and that is even when the sun is at its strongest.
Any reason why the heater should be replace because of switching to salt?
Really informative. Thank you. I do agree. It’s a 50/50 with the UV light. I think what the pool company and Pentair are trying to accomplish have it help enough so I don’t have to run pump 24/7 and can use one IC60. My cousin father in-law switches 2 years ago it a UV light and regular chorine and he said he uses about 30% percent of what he used before.You can read this post I wrote regarding UV -
Can I leave pucks in my in-line chlorinator when it's off?
You can certainly use UV as an add-on to your system but it’s not really considered a sanitation source for pools by the EPA. It can certainly kill some nasty (but rare) pathogens but the cost/benefit ratio is pretty poor.
