need advice please. Mine is being built now . 18” raised seems so high now when get in it, and hard for me to get out of spa and see over it to the pool when sitting down In it . Internal is 20” to bench and another 20” to top, and this is before pebble tech and coping is put on, so will be even higher later. Seems like I will feel as if in a large hole, or does it seem this way now cause not finished and no water in it. I keep thinking it may be 18” outside but what is It to be on inside depth? The PB suggested step in corner near the waterfall where we did not put bench that would allow me to get out, any other ideas? They said no other way to fix or change now due to rebar and plumbing. Any other suggestions?
also, sports pool and levels don’t seem right On bottom, how should it flow down? Mine is 30’ long.
