Hi, we are building a gunite pool and raised spa. The spa has a 7.5' wide spillover into the pool. The waterline, spillover ledge, and the vertical face of the spa below the spillover will all be tiled with the same tile; a 2"x2" porcelain NPT tile. Will this work? Is the spillover too wide? Should the spillover ledge be level, with a slope towards the pool, or a slope towards the spa? Are there too many grout lines with a 2x2 tile for this be more than a trickle? And will the grout and tiles fail? I look forward to hearing your thoughts.
