- Jul 8, 2011
- 30
Hi All,
I have a Jandy AE-TI Heat Pump connected to my 20,000 gallon in ground pool and in the 10 years we've owned the pool it has never worked (due to an expensive-to-replace broken controller assembly). Recently the petcock that's part of the heat exchanger drain has sprung a leak and I can seem to find a plug to use in place of it. Given that it's pool opening season in MD and no one will make service calls, I'm stuck with a leaking and poorly filtering pool.
So my question is: based on the photos below of my filtration system layout, can I remove the heat pump altogether and just install PVC in a u-shape to continue the flow? Trickiest part seems to be disconnecting the electric or ensuring that my plumbing is dry in order to use PVC cement on it.
Advice welcome!
Advice welcome!
