Need Advice - Can a DIYer remove a Heat Pump?
jenandthegang
Active member
Jul 8, 2011
28
Hi All,
I have a Jandy AE-TI Heat Pump connected to my 20,000 gallon in ground pool and in the 10 years we've owned the pool it has never worked (due to an expensive-to-replace broken controller assembly). Recently the petcock that's part of the heat exchanger drain has sprung a leak and I can seem to find a plug to use in place of it. Given that it's pool opening season in MD and no one will make service calls, I'm stuck with a leaking and poorly filtering pool.
So my question is: based on the photos below of my filtration system layout, can I remove the heat pump altogether and just install PVC in a u-shape to continue the flow? Trickiest part seems to be disconnecting the electric or ensuring that my plumbing is dry in order to use PVC cement on it.
Advice welcome!
jenandthegang
Active member
Jul 8, 2011
28
Thanks for the reply Marty. Is this the right way to do it?
Plumbing:
  1. shut off pump
  2. close valves on either side of heat pump to prevent water flow
  3. drain all water out of the pvc in that area
  4. cut pvc before inlet and outlet (would you do it before the coupling?)
  5. install a new u-shaped connection using pvc cement
  6. let dry for recommended time
Electric:
  1. turn of electric to panel box
  2. remove heat pump electric wire tied to panel box
Any other thoughts/ideas?
Reactions: markayash
CJadamec
2,390
Quaker Hill, CT
Cut the PVC leaving the entire union in place. If you take that front plastic cover off the heater you will probably have better access to the PVC to make a clean cut.
Glue a cap on each stub open the bypass and have a good swimming season.
Make sure the breaker is off and undo the electrical. Try to sell the unit on craigslist (listing the bits that are broken) or have somebody take it away for free if you aren't planning on fixing it. It's probably around 200lbs in weight so be prepared for that.
