Since ph additions tend to be cyclic and very predictable if you have a high TA or a SWG, a regular stenner type pump with timer or controlled bye the ET as i have is more than enough and less variable and much less expensive. I bought the intelliph initially but the control board lost its magic smoke very early, i decided to connect it to the ET via a relay that i control with a schedule. That was a 600 usd expense. If you buy a simple stenner and buy a plastic 5 gallon tank on ebay or amazon it will be a fraction of the cost and do the same thing.
Now for the ORP side, it only measures the a reduction potential which is affected by many Chems, FC,Ph,Cya, etc.. Which it doesn't actually measure FC alone. Since you need some CYA on an indoor pool(so FC does't feel harsh) this affects the orp readings. Some guys have made it work on indoor pools, but will take more of your time and effort. KISS principle applies.
A SWG, and a stenner for acid additions with automation, does not get any better.
good luck
