Hi Everyone,
Semi-pool noob here, my SWG pool turned 1year old last week. I learned a lot this past year, and have made some great changes that have helped tremendously, mostly found on this forum!
Anyways, my reason for this post, is calcium buildup on my SWG. I cleaned my SWG a total of about 7 times these past 12 months, every single time using diluted Muriatic acid (5to1 water/acid) as recommended by the manufacturer. I have tried to wrap my head around why my SWG collects so much dang calcium deposits.
I cleaned my SWG 2 days ago, and there is already a thin white film covering the fins, is this normal? I know cleaning with diluted acid will eat away at the precious minerals on the plates of the SWG, but there is no way to manually clean it with wooden sticks/popsicle sticks/paint stirs as ive seened mentioned here, the white calcium chunks are incredibly hard, ive succesfully knocked off some large chunks with a metal screw driver (completely avoiding the plates of course) but there is no way the center of the plates are getting cleaned without the acid.
Here are my pool deets and my most recent test using a TF-Pro Salt Test
10,000 gal Gunite/Concrete pool
Located in Central-ish Florida, Port St Lucie to be exact
Uncovered, almost no shade/ no trees
Hayward TurboCell S3 Salt Cell TCELLS325
Most recent test results
FC-7
CC-0
PH-7.5
TA-60
CH-500
CYA-50
SALT-3100
Temp-82*
CSI- (-0.300)
Any insights or recommendations would be extremely helpful!
thank you!
FC-7
CC-0
PH-7.5
TA-60
CH-500
CYA-50
SALT-3100
Temp-82*
CSI- (-0.300)
thank you!
