My testing kit is delayed
Pepperdinegal
109
Las Vegas, NV
I have an old school Jandy PDA. My question is, where do I add the chlorine/bleach and acid? You had said the “return jet”, but I’m not sure what or where that is.
Also, when adding the granulated CYA, I’ve read about the sock method but am I sure whether it means an actual old white tube sock or a nylon skimmer sock.
ajw22
24,667
Northern NJ
Pentair Intellichlor IC-60
Where does the water come out of pipes into your pool? They are typcially on the sides of your pool wall or if you have an IFCS on the pool floor.
Those are your return jets.
Use an old white tube sock.
ajw22
24,667
Northern NJ
You will note that Allen grabbed a pair of socks in his photo.. if you need more than will fit in one sock use two.. you have 8 return jets. ALSO it prevents the dreaded orphaned sock syndrome.
I sometimes get 3 socks going.
JJ_Tex
2,316
Prosper, TX (DFW)
Pentair Intellichlor IC-40
Please forgive my ignorance, but can you clarify what the “return jet” is?
Edit - Disregard, I got distracted in typing my response and didnt see it was figured out a few minutes ago.
I'm speculating here, but are you looking at the equipment pad to try and find the return jet?
If so, you would never add chemicals at the equipment pad. You would want to add them to your pool in front of a return jet (usually under water on the walls of the pool, and has water coming out of them from your equipment... ie, it is returning to the pool from the equipment). Pour it in there and the water coming from the return jet helps mix it in with the rest of the pool water.
mguzzy
Pepper, you can squeeze the socks too, to get the process moving along. The concept here is to to get the CYA into the pool water. Most instructions on CYA packages say to dump it into your skimmer.. that just clogs things up until it dissolves.. that's why this is a better way..
