You don't normally need to keep adding CYA to keep levels up unless you replace a lot of water...
Okay, thanks!
Also, do all my levels look okay at this point?
So...you paid $1000 for them to clear the pool, and they didn't? Did you get any money back?
There are a few issues you may run into with your levels, however at this point focusing on the FC level is key. Worry about other levels once you're swimming after completing the SLAM process.![]()
Your original post is confusing...
you say "$1000 later, no fix"....
but you haven't spent anything on that....
it will be interesting to see if they send you a bill, and for how much.
