TL;DR: Likely bad capacitor, found a colony of ants inside my pump, and I'd like to get suggestions regarding the best way to protect this pump from the elements if possible.
Hayward super pump, about 10 years old. 100% exposed to the elements and has likely had the filter leaking onto it for awhile now (years?). Pool and all parts are original from 2007 to the best of my knowledge (we purchased the house and pool in February of this year and I've been using TFPC since Day 1 with great success).
I went to add some chlorine to the pool today and turn on the pump to distribute it, and all I got was a buuuuuuuuuuzzzzzz for about 5 seconds and then a *click* as it turned off. Lovely, less than 1-week before my daughter's 4th birthday party, which we have planned as a pool party.
After some quick googling this is likely a bad capacitor, so I disconnect the pump to bring it inside for disassembly and get the capacitor specs.
First I turn it over and find out the bottom is severely corroded due to basically sitting on a pile of wet leaves and organic material, and the pool filter leaks a decent amount onto the pump, which isn't helping things. I tried to fix that leak in this thread with zero luck.
So I get it inside and set it down and start taking it apart to inspect things, and...ANTS. Ants everywhere. Thankfully not fire ants, but ants nonetheless.
A variable-speed pump is out of my price-range right now so I'm trying to figure out if I want to try to replace the capacitor for $5 or the motor for $200.
