Could use someone smarter than me - Have a dilemma
Pool - PebbleTec - 26000 gallons - Salt Cell- Sand Filter - Dolphin Cleaner
Last weekend, drained, bead-blasted - acid-washed Pool - Cleaned out the Sand filter and topped off a bag of ZeoSand to replace what got pulled out and filled on Tuesday - Rinsed pool out - drained and done
Filled Pool - Fired Up - ran filter on BW from the new zeosand and for a final cleaning for 5 min. Water clear Started Filter,
- added 800 lbs of salt while filling,
- added Muriatic acid to bring it to 7.4
- Added 3 Gallons Conditioner to Skimmer
- Added a gal liquid Chlorine and a couple of tablets and a bag of Shock to get the Chlorine up
Next-Day Things were a bit Murky - Checked Chems - Needed Acid - Chlorine was good. As we were leaving town the next day for the weekend, I decided to teach 24 yo Daughter how to test Chlorine and PH - Tossed in some flocculant before I left with chems in good shape, just a little murky
When gone, she keeps telling me its murky 5 days later she tells me it is still murky - I just told her to make sure there is chlorine in it
Turns out - she did not add any acid - only chlorine (bottles mixed up)
Get home - my Pool looks like a milk shake This white water - never seen anything like it -
Get water tested - results:
FAC - 12
TAC - 12
Salt - 3800
Calcium - 190
Cyanuric Acid - 70
TA - 150
PH - 8.0
Copper -0
Iron - 0
Phosphates - 100
So I am adding Acid - 1.5 Gallons to get the PH down - but any ideas on why my water is a murky milkshake - Can Barely see the top outline of the top step
Does anyone have a clue on this mess? Thanks in advance - Brian
FAC - 12
TAC - 12
Salt - 3800
Calcium - 190
Cyanuric Acid - 70
TA - 150
PH - 8.0
Copper -0
Iron - 0
Phosphates - 100
