My pool pump stopped priming after I modified some piping...
miamicuse
126
Fort Lauderdale, Florida
Hi, first time posting here looking for some help to trouble shoot a problem.
In summary, this is a property I just purchased and so everything is new to me, and I do not have any prior experience in dealing with pool equipment, but am handy and know my way around home repairs, plumbing and electrical. Basically I had some leak(s) and after fixing those leaks my pump no longer seem to prime.
My apologies if the post is too long. It may take some explanations and pictures to clearly illustrate my situation.
Existing conditions: I have an in-ground pool and a separate spa, and the pump and piping are working for both. The pump is on an Intermatic timer and runs from 8am to 4pm daily and didn't have a problem for the few weeks I have owned the property. Recently I noticed a slow leak on the outlet joint of the pump, where a 1.5" male adapter threads into the pump.
103180
Now to fix this leak is not a big deal, just need to cut the pipe above it and tighten the male adapter and remake two joints. But after looking at the entire plumbing, I concluded that I need to take care of a few things at the same time.
Here are some additional pictures of the entire setup from different angles.
103182
103184
As you can see, and hopefully agree, that there are some issues.
(1) Both the pump and the filter next to it, are buried under leaves and dirt. The pictures you see here, are the ones taken AFTER I cleared most of the leaves out. At the time, I didn't know the bottom of the pump and filter were strangled in tree roots as well.
(2) Between the pump and the suction side manifold, there is no exposed piping. In other words there is no easy way to disconnect the pump for service or replacement.
(3) I have a leak at the outlet joint of the pump.
So my plan was to redo the outlet connection to the pump, raise the pump, raise the filter, and put a union on each side of the pump to allow for future disconnect.
The first problem I ran into was the pump and filter had lots of tree roots enveloping them, and clearing them was a real pain. Second problem is since there is no exposed piping between the pump and the manifold, the only way I can disconnect the pump is to excavate enough roots and dirt from under the pump so that I can rotate the super heavy pump in reverse to save the male threaded fitting. Despite all that I was able to do that and here are some pictures of the revised outlet side plumbing.
103186
103187
103188
I put some blocks under the pump to raise it about 12". I also put some stepping stones to raise the filter about 3". During the process to excavate the pump and filter's bottom I found another leak coming from the drain plug of the filter. It was loose and it was losing water much faster then the pump's outlet joint. The leak caused the dirt there to be all mushy and I believe attracted all the roots towards it.
103189
So far I fixed two leaks. I then turned the pump back on after all the new joints had 12 hours to set. The existing leaks are gone, a new leak developed on the return side (more on that later). The pump runs and I noticed it seems to take longer for it to prime but it did prime after a few minutes. I declared victory and problem solved (or so I thought).
A day later I was reading about some pool maintenance blogs and ran into an article that says you should never, ever have a 90 elbow into the pump inlet side. Oh oh...that's exactly what I did. Not one, but two as I needed to raise the pump off the ground, and I inserted two 90s to offset the pump higher. So my question #1...did I make things worse by doing what I did? Do I need to take it apart and redo everything differently?
Another day gone by and I noticed a new leak on the return line. I say new leak only because it's one I may not have noticed before. I don't think it was leaking because I looked and touched all the pipes and joints when I recon the system the first time around, but now I am not 100% sure. The leak occurs where there is a "loop" between the pool return line and the spa return line. I also do not know the purpose of this loop. Let me see if I can illustrate the loop in these pictures. Here is a picture of the overall system.
103191
Here is the same picture, where I traced the return line in green lines. As you can see, the return line runs into a Jandy 3 port valve then splits into the pool line on the left and the spa line to the right. But before those two lines enters the ground, there is a tee from each and the two are connected via a U shaped loop (in orange color). I have no idea what that loop is for.
103192
Here is a picture of just the loop. From the pool return line, a tee. The tee then goes into a ball valve (which is always in a CLOSED position), then it turns around into a check valve (with a flow direction going to the spa line). My question #2...any idea what this loop between the pool and spa lines is for, with a ball valve and a check valve it seems to be deliberate?
103197
At the inlet to the ball valve, connected to the pool return line, is another leak. It looks like someone had attempted to fix it before, as I can see some putty like substance all over it.
It seems I have reached a limit of ten images and I still need to add more illustrations. So I will continue with the next post. Thank you for bearing with my long post. :)
...continuing from my last post. Here is a schematic of the piping. The section in red is the loop I am confused about, and there is a leak there. I called the previous owner, and he said he has never messed with that ball valve, it has always been in the closed position, and he has no idea what those pipes are there for.
Not knowing what the loop is for, I am not sure how to properly fix this leak. But knowing the ball valve was always in the closed position, I decided to cut the loop and terminate both sides as a temporary fix. So here is a closed up of what was existing.
103201
and this is what I plan to change it to, for now.
103202
I went ahead and cut the loop out and this is what I have at this point. Added in a new coupling to each, then a male adapter, then capped. I can always open them and join them if necessary.
103203
After that, I turned on the pump and it will not prime anymore, I let it run for an hour and still nothing.
I rechecked everything. On the suction side, I had cleaner OFF, skimmer OFF, main drain ON. The 3 port valve is set to close off the spa side and pool is wide open. On the return side, the 3 port valve is set to open to the pool and closed to the spa. The pump runs and runs and won't prime. I scratched my head and turned it off to think it over.
Next day at 8am the pump kicks on, I already left for work. I came back around noon and heard the pump running. I saw it still hasn't primed. The PVC pipe on the outlet side is very warm. I turned the pump off and opened the lid, steam came out. The water inside is HOT.
Any idea why my pump won't prime? Is there any chance what I did to that loop caused this? I can't imagine it is related. It is on the return side and usually the priming has to do with issues on the suction side, right?
The strainer basket is clean. Pool water level is normal. I checked and rechecked all valve lever positions.
There is no visible leak on the suction side. It was priming even after I raised the pump and put in the two 90s. Now that I tried to fix the slow leak on the return line, it won't prime.
Any recommendation what to check next?
or is this a pump failure just at the wrong time?
M,
The line that you capped off is called a "Make up line"... It supplies water to the Spa, when in the Pool mode... This causes the spa to fill up and spillover into the pool.. The check valve prevents the spa water from draining back into the pool when the pump is off. The valve turns the overflow off and adjusts the amount of overflow..
M,
Jim R thank you for replying to my insanely long question.
I see. If I understand you correctly then this is for a pool and spa where the spa is built higher at a corner of the pool and spills into the pool?
Wouldn't the Jandy 3 port valve achieve the same thing if I turn the lever to half way between the pool and spa return line?
But I see if you turn the lever to OFF for the spa and all the flow goes to the pool return line, it can still divert part of the return flow to the spa but not the other way around. However, in my case, my spa and pool are not built together. So I don't see a scenerio where I would like the spa to spill into the pool.
103262
103263
In any event, I am guessing that my capping those two lines have nothing to do with the pool pump suddenly not priming? Even though the timing is such that after I capped the line the pump doesn't prime anymore.
If the pump was left on for four hours, and didn't prime, and the water inside the housing is almost boiling with steam coming out when I removed the lid, and the outlet PVC pipe on top is VERY warm. Is there a very high likelihood the entire motor needs to be replaced or can it still be usable?
If I disconnect the electrical, then remove the six hex bolts connecting the motor to the housing will I be able to examine the insides of the motor?
If the pump was on for enough time to make the water boil, it can warp the wet end of the pump and/or the pump lid.. The result can often be that you can no longer get a good suction seal and the pump will not prime.
On your spillover.. Your spa may be connected to the main pool by pipe between the two.. The make up valve would just pump clean water into the spa that would cause the water in the spa to flow out the pipe and back to your pool.. Capping off the lines has nothing to do with your priming issue.
What I don't understand is whether what I did to the piping may have caused the pump not priming.
It was working fine before.
Then I dug out the pump from being half buried in the dirt and raised it about 8 to 10 inches. Added in two 90 degree elbows on the inlet side where before was a straight run. I found out later this is not desirable, but at that time the pump still prime but took longer.
Then I fixed the last leak on what Jimrahbe called the "Make-up line" between the pool and spa. I terminated that line which again should not have any effect on the pump.
After that it will not prime anymore, and I am scratching my head.
My guess would be the union you added. If not sealed properly, the pump wont prime.
In pool plumbing, sometimes air can leak in without water leaking out so it is not always visible.
Wow, you nailed it, It WAS the union. I took apart the unions before and after the pump, and re-tightened both, and it primed.
What was confusing me was it was priming after I added both unions. Then it didn't prime. What happened was I did take apart the unions once to apply some silicone grease on the union o-rings, and evidently I didn't tighten the unions well enough, and affected the priming.
Thank you so much for spotting the problem :goodjob:. I was hitting my head against the wall there.
Now that the priming issue has been resolved I have a new leak on the outlet side which I will ask about in a new thread since this one is a bit convoluted.
My remaining two questions are:
(1) Is the offset from the suction side manifold involving the two 90 degree elbows going into the pump inlet OK? The articles I read about this being a NO-NO so should I redo it a different way? Given the current configuration I can't think of a way to eliminate the two 90s unless I go back to having the pump half buried in dirt, or I raise all the piping on the suction side.
(2) In order to fix the leak I had on the return line, I capped the "make-up" line from the pool to the spa. Should I keep them capped or should I put back in the line with a ball valve and a check valve? I do not have an integrated higher spa inside a pool, I just have a pool and a separate spa.
Did the article say why you shouldn’t have a 90 in front of the pump? That’s not a bit of “common wisdom” that I’m aware of.
Jim had a good point about there possibly being a pipe connecting the spa to the pool. That makeup line would help keep the spa full and have some water circulate through it and keep it chlorinated even when it isn’t in use.
The 90 in front of the pump should not be an issue. That requirement only makes a difference when pump inlets are connected directly to pipes instead of the pump basket.
