As mentioned I have an ionizer, if I want to use BBB method can I leave the device on as normal? It is attached to filter before return jet. Should I just put level to zero, is the only downside to leaving it on the possibility of copper staining?
If I want to remove (perhaps at end of season, can I just take it off when winterizing, and not reattach when the pool is opened?
Will try to post pic
