My yard flooded into my pool 3 wks ago, I have vacuumed and backwashed numerous times. It has gone from muddy brown to cloudy green. I added 2 Lbs of shock 4 days ago and another 2Lbs yest. Still liiks about the same maybe a little better but still green/cloudy. Here are my chemistry readings: should I start by adding stabilizer to get my CYA to 30-50? I have never used the SLAM process so not sure what first step should be? slam/ more shock/ CYA level?
Thank you for your help.
Taylor K-2006c service complete FAS-DPD chlorine)kit used: ( I started with CL of 0 and Ph 7.3 before I added shock)Now I have:
PH 8
FCL8
CCL 0.2
ALk 40
CYA 0
My pool company using there tester got this( not sure why CCL is different from my readings)
PH7.8
FCL 6.1
TCL 8.5
ALK 42
CCL 2.3
CYA 5
Salt 3400
PH 8
FCL8
CCL 0.2
ALk 40
CYA 0
PH7.8
FCL 6.1
TCL 8.5
ALK 42
CCL 2.3
CYA 5
Salt 3400
