Well then you are not adding enough chlorine if it continues to read zero. The only other explanation is that the test kit you are using is so bad that you have too much chlorine in your pool and it is making the test reads 0
Sorry things are not going your way.
Please add your pool details to your signature as described HERE as it will help us help you.
How big of a pool are we talking about here?
What test kit are you using?
Please take a look at these in Pool School so we can talk the same language:
ABCs of Water Chemistry
Recommended Pool Chemicals
How to Chlorinate Your Pool
Just saw your added question. The answer is you use PoolMath to do the calculations for you. Enter your test results, enter your desire level, and bam it tells you what you need to add.
Note I also merged your 2 threads as we were already duplicating efforts and asking the same questions. Please keep all your questions in here for now.
A lot of people are trying to help you but you don’t seem very receptive to it.
Simply adding chlorine isn’t going to solve the problem if it isn’t enough chlorine, you’re not maintaining those correct levels and you don’t have numbers to give them.
I'm sorry. I guess I'm missing the "help".
Like i said i don't understand any of this. I don't know what I'm supposed to do. I know nothing on this pool works right & i don't even understand a little bit of this.
I read the ABCs. I read the pool school stuff.
I don't see any solutions. I'm just lost.
