- Jun 7, 2017
- 9,966
- Plaster
- Jandy Aquapure 1400
The bond beam appears to be in tact all the way around the pool. Some of the rebar is exposed but I’m guessing that was the construction method used - perhaps the shell was shot to top of rebar. Then the deck was a single pour cantelivered over the shell. There are many mysteries still as to why it was filled in the first place as the shell still seems to be in good shape overall. I do know the previous owner was in his mid 90’s and took a reverse mortgage out. The lender told him to either get the pool in running order or fill it in. Considering the actual trash and other items including large trees trunks etc that were in the pool it may have been cheaper if there was filtration or main drain issues to simply fill it in - and don’t forget they didn’t comply w the local requirements when filling it in as there really was no drainage holes punched in the bottom. Not sure even if the main drain hole goes all the way through the shell.Is there a bond beam on the shallow end or has it been knocked out?
That is not what I was hoping for. Only the top 1’ or so appears to be in bad shape. The rest of it doesn’t have a crack in it.That shell is in really bad shape. I suppose you could rebuild it but I think you are going to have to use it with a liner I don't see that ever being a plaster pool again. Not that it can't be salvaged but no builder would ever attempt it they'd demo it and start from scratch. Be interesting to watch though!
My only problem w a liner is dogs. I have 2 labs that will be literally living in the pool. I see problems w holes.I'd definitely do a liner. They're good for 15 to 25 years, and much cheaper to replace than a replaster.
Thanks for the reply. The floor to wall transition seems very tight with no gaps or cracking present. I plan to dig around the pool this weekend approx. 30" deep in preparation for plumbing work. I am on a pretty decent hillside so keeping water out of the dig will be very difficult plus the hill on the lower side of the pool leads to a neighbor who has already complained in the past about mud runoff during a previous project so I am doing everything possible to avoid any issues. I am hoping if that dig around the pool (30" deep) fills with water it won't create an issue with the pool "floating" - it is a 12" thick pool and it has a hole in bottom where the drain was (which is actually still holding a little bit of water from the power washing this weekend. I think the clay around the pool is preventing any drainage. Getting the shell core drilled for new plumbing will be an easy task - I do business with a company that core drills for a living. And clean concrete is a must, but bonding of structural concrete for pools is way out of my league - my experience lies in flatwork. What type of concrete and bonding agent should i use? I don't have much help on the weekends other than my 15 year old son - most of my union field workers have had enough fun by Friday afternoon (60-70 hours) and no amount of money can entice them to work on Saturday. Is this something that can be done in small 20' sections. I imagine that a 20' section would possibly be manageable for a father / son team. I can definetely get all of the shell prepped and rebar repaired / replaced on the whole thing - but actual concrete work in sections. I would also need some guidance on skimmer install as it did not have them before (only a main drain in deep end). It seems that skimmers would interfere with the existing rebar in the bond beam. Do you cut that rebar and then run new rebar around the skimmers and then tie it all in together? Lot of questions and I still have a long way to go before I am ready for concrete work.It would be alot cheaper to liner this pool in the bigger picture. With these older poured pools you have to take care to inspect the floor to wall transition they often poured the floor first and then the walls. If you definitely want to repair the bond beam amd start the process of a rehab take some time and fix the grade around the pool. Get rid of the dirt above the pool height amd make a swale so all rain washes away from pool. Free up the backside so you have plenty of room to work on making forms amd be able to keep it clean. I read you have concrete experience so you already know how important clean concrete is and what to do with bonding agents. Your going to have to plumb the pool so if you have access to a mini excavator that's the ticket. Post any questions you have I'll guide you along
Cool old house. Sure would like to see a few pics of that restoration.![]()
