How do I manage the pollen in my Pool? Do I run the pump longer to filter the water? Do I need to skim? I’ve read adding phosphates could help it clump together. How do I know if it’s a problem? I’m in GA.
Do you have a gauge on your filter? If so, we suggest cleaning it when the pressure rises 25%. above clean pressure
Maddie
mine doesn’t seem to climb all that quickly. How often is that for you?
