thanks rich. i really need to get into this Dang pool. today was a beautiful pool day. i will continue pre-filtering it really seems to get some of the finer silt. i still lack a vaccum, this is helping.
jblizzle said:Correct. Have you tried the OCLT yet to see how much is still consuming the FC when the sun is not a factor?
jblizzle said:What does the pressure gauge read?
The pressure in the filter should be released as soon as you turn the pump off ... as the gauge should also show 0psi. You do not need to open the filter to change the gauge.
jblizzle said:Ah, sorry about that.
It is very rare, and basically impossible for the pool pumps to over-pressurize the filter. They are designed for 50psi and pumps are lucky to get over 35psi or so.
As such, it seems to me that there may be a problem with the pressure release valve. Are you still getting flow into the pool?
jblizzle said:If you are getting good flow back to the pool, there is no way the filter should over-pressurize. Wondering if maybe you have a little piece of crud stuck in the pressure release valve so it is not fully closing.
