thanks - hopefully the rain doesn't come before that; it's getting gloomy out there.jblizzle said:You can test an hour after adding the bleach and it will be mixed.
armedmetallica said:if rain does start, i wont be able to get a good read again until 24hrs from now.
jblizzle said:armedmetallica said:if rain does start, i wont be able to get a good read again until 24hrs from now.
Why? Are you a witch that will melt if you get wet? Or a Mogwai that will multiply?
You can be sure anything in the water does not care that it is raining
armedmetallica said:new test!
pH 7.2
FC 14.5ppm
CC 0.5
TC 15ppm
TA - 50 or 60 (i think i screwed up a drop)
CH - 100
CYA - started disappearing around 45, completely gone at 60.
sooooo.. i'm not really at shock yet right? I need to dump in MORE bleach? chart for SWG pool says shock to be at 24?
kjpool said:armedmetallica said:new test!
pH 7.2
FC 14.5ppm
CC 0.5
TC 15ppm
CH - 100
is your pool clear? sounds like you might be done shocking. did you do the overnight test?
Correct, you are not quite there. Shock level is between 18 and 24.sooooo.. i'm not really at shock yet right? I need to dump in MORE bleach? chart for SWG pool says shock to be at 24?
You don't worry about anything but FC and CC during the shock process. Once the algae is gone, the rest is easy to shape up. When the pool starts looking better and the CC stays down, then you worry about passing the overnight test.armedmetallica said:so - get to shock first before I do the overnight test? do i need to do all the tests each time, or just the chlorine related ones daily and then the others somewhere in betwwen?
this kit is awesome -reminds me of my college years in chem class.
Nope. The skimmer sock is like a prefilter.armedmetallica said:UPDATE:
at 24 FC earlier today... that step to check for CC, the color seems lighter and lighter each time, i'm guessing that's a good thing?
Today, I scrubbed all around the pool, an had a filter sock on the basket... got a LOT of gunk/debris out. to the point where it suffocated the water flow into the pump. was afraid to leave the sock on overnight in case it happens again. will see if i have some time tomorrow to repeat the process.
since I added CYA 3 days ago, should i NOT do the filter sock thing? is it akin to cleaning the filter?
