My AquaSport 52 Build
koffey
213
Toronto
The oil resident left over is from the straps. You typically don't see it in lumber because it soaks in and dries and it sometimes stains in non-pressure treated applications. Composite boards don't allow for this. That is what I suspect it is. I love the white pillars, it provides contrast and blends with the white of the pool. Would it not have been possible to make a jig to help with the cuts? Although I assume it wouldn't be 100% accurate all around the pool either. But amazing job!
How hot are those boards getting with the sun? Splendid job man, splendid.
mgmercurio
76
Louisville, Kentucky
Thanks for the kind words Koffey...I really appreciate them. Yes I thought about a jig and quite frankly, it would have been very easy to make...but the post sleeve base offers almost a full 1" of coverage, so I thought...I shouldn't make any mistakes larger than an inch! LOL but then again...ya never know...heh heh. Finally as for the deck boards' heat...they are EXTREMELY HOT! I can't even kneel down on them wearing full-length blue jean pants...the heat just goes right through my jeans. Luckily, I use knee pads that protect me from the heat. The funny thing is...the guy at Lowes (where I bought the Trex from) said that out of all the colors of Trex decking, grey is the coolest! oh boy...you most definitely have to wear flip-flops while walking around on the deck if you are going to go swimming.
And thank you for the info on the oil residue....it does come off...but with a fair amount of elbow grease. ;)
Thanks again!
Reactions: koffey
koffey
213
Toronto
There's a really good write up on comp decking and it's temp somewhere on the web. If you can, you should now buy some more of them screws clips. They will break off eventually and you want to make sure you have some on hand. It happens mostly in the steps. Not sure if you have that.
Reactions: mgmercurio
mgmercurio
76
I will look up that write-up and read about it. I can't believe how hot those boards get! I'm pretty sure they are as hot if not hotter than asphalt. :(
koffey
213
Toronto
Found it
YippeeSkippy
20,301
Evans, Georgia
I always try to warn folks about how hot Trex gets. Your pool deck is drop dead gorgeous.... but hot. One of those new fangled outdoor rugs in grey & white placed on the deck would help swimmers walk around yet not distract from the pretty deck.
Maddie :flower:
mgmercurio
76
Maddie :flower:
Thank you for the kind words! Yes that is a great idea...I will probably lay down some sort of indoor/outdoor rug ;)
