frustratedpoolmom said:Rubygrrl said:[
I would be thrilled if I could get the CYA down to 60!! Do you have any estimate of how many drains (if we just drain to right below the returns) it will take to get us that low?
I put in a small jug of bleach last night as it was filling--should I do that again this evening?
I know that my first priority should be lowering the CYA--and then use my new CYA number and shock it at the mustard algae level (using the chart). Water is still super cloudy--but it's not NEAR as green as it was last Thursday and Friday---it's more blue-green now.
So, is putting in a little bleach pointless? I just don't want my FC to fall too low..
Thanks again for your help frustrated pool mom. I see you had the same problem I did back in 2007.
I really want to drain more of the pool--but we can not afford to replace the liner at this time, so I don't want to do anything that could harm it.
I'm really trying to have POP--but it's hard. I just hope we only have to drain 1-2 more times max.![]()
Someone smarter than me that's a wiz at percentages knows how many partial drains it would take, but he's out travelling the world. Maybe someone else will offer up their knowledge. How far down is the return? I would guess 2 more times max if it's 8 inches or so. Total Guess.![]()
Yeah, kinda pointless, but it can't hurt. (adding a little more bleach)
Can I make a suggestion? Try shocking to the "normal" shock level, not necessarily Mustard Algae level after you get the CYA down. Just try and see if it responds to normal shock levels. I think it will, but I could be wrong. Frequent, very-high shock levels for prolonged periods can bleach out your liner.
So stick to the regular shock level when the time comes, for a couple of days...see how the pool responds. I'm not convinced that's mustard algae.
I know it's hard, been there, done that....you'll be FINE!![]()
I think I have already bleached the liner some--but it's not THAT bad--so I will certainly take your advice and use normal shock levels.
I measured--and we drained 12 inches last night--and we are draining another 12 inches now. I am about to start filling it--it's nearly done!
I don't mind doing a bunch of partial drains--it's just that I am really impatient! LOL!
