Hey TFP!
As a little background, I bought a house (my first) mid summer last year with a 18x36 IG (23,000?) gal vinyl pool (also my first).
After a few trips to the p∅∅l $tore, and a few shades of green later, I realized something they were t(s)elling me wasn't right. After discovering TFP I binge read every topic under the sun for a week or two, then 2-3 days of SLAM later I was crystal clear and enjoying my investment. - so thank you!!
Sorry for what will inevitably be a very long post, but the TL;DR is:
After opening my pool(swamp) for the season using strict adherence to TFP methods, everything turned blue nicely, but it's been over a week and the water is still too murky to see the bottom of the shallow end. (the same murkiness level of 24 hrs after opening)
Details:
Rewind to last Friday - I opened the pool (swamp), albeit a little late in the season from what I gathered (For Chattanooga) - All equipment back up and functioning normally - after a quick dose of MA, tests (Taylor K-2006C) showed
FC/CC - 0
PH - 7.2
TA - 50
CYA - ~10
CH - 20
(FYI Temp ~65F)
Threw ~2 lbs of CYA in a sock, and everything else looked ready to SLAM. Bought WallyWorld's stock of chlorinating liquid and got my FC up to 10-15 and maintained it. Swamp turned blue almost immediately, but still had the grayish hue of dead algae, and very murky. I had experienced this before, and expected it to clear up in AT MOST a week, but more likely ~48 hours based on past (sand)filter performance.
Checked CYA 48 hours in, shows 25ppm, added another 3lbs of CYA for good measure.
Performed two OCLT's Tuesday & Wednesday, both passed. Still murky, but more of a white hue, not so much gray. (Seemed indicative of high CH, maybe? But not according to the test...)
So yesterday I decided to turn my filter 'up to 11' by throwing in some DE (never had to try it before) . Carefully measured my 1/4 cup at a time, waiting 5 minutes between just in case. got to 3/4 cup and saw a 1psi increase, waited by the pump for 15-20 minutes or so, psi held. Went inside for 10 minutes, came back out and my psi had increased 50%. I did a very brief backwash, threw in just a pinch (1/4 cup) DE, started again. 1 hour later, no pressure increase (not even 1psi).
I get up this morning, only about .5 PSI increase, no change in water. (FC 14, CC .5)
So that's where I'm at now, spent almost my whole month's utility budget on electricity already, and am almost out of my 25 bottles of the elusive (in my area anyway) 10% LC, from maintaining SLAM for so long.
I'm going to try vacuuming again now, just in case there's something lurking down there that I missed, that could be causing this? That's my only remaining idea.
Feeling a little despondent... Any suggestions would be greatly appreciated. : )
Details:
FC/CC - 0
PH - 7.2
TA - 50
CYA - ~10
CH - 20
(FYI Temp ~65F)
