Muriatic Acid
The higher the acid % is, the stronger it is, and the less you need to use.
I use 31% which is the highest strength you can get to lower pH.
Use a lower % and it will take more to get the same effect.
What do you mean "cleaning salt"?
Sorry I edited it. I meant salt cell and basically just wasn’t sure if certain % was harsher on pool or equipment but reading your comment I imagine wouldn’t make a difference cause you would use less or more depending on %. Thx appreciate response
You clean a salt cell with a diluted muriatic solution as a last resort. The lower % needs less dilution.
You should try less damaging cleaning methods on a cell before you resort to a MA solution as described in SWG How It Works - Further Reading
